Acura Integra 94-01: Headlight Halos
Old Jan 12, 2003 | 12:07 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Default DIY Halo's for Integra(3rd gen 94-01)
Check it out. :thumbup:
Old Feb 20, 2003 | 07:32 AM
TriniSpeed's Avatar
TriniSpeed
does it matter which side you cut the notches in? which side are you suppose to put the aluminum foil?
Old Feb 23, 2003 | 06:37 AM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
The only thing I seen that needs to be notched are the backplates, which are notched on both sides. The aluminum foil goes over the hole headlight assy, only leaving the seam exposed.
