no heat? help
Old Nov 16, 2005 | 11:59 PM
92b18hatch's Avatar
92b18hatch
Default no heat? help
i have a 92 civic hatch with a b18c swap. yesterday i had no heat. so i replaced the thermostat and changed the coolant.that did nothing for me. any suggestions?
Old Nov 17, 2005 | 06:25 AM
JimBlake's Avatar
JimBlake
Check to make sure the heater valve actually moves when you slide the temperature control lever. If it doesn't, you can look for a broken or disconnected cable somewhere behind the dashboard.
Old Nov 17, 2005 | 11:09 AM
92b18hatch's Avatar
92b18hatch
it moves, it seems like coolant is not moving at all. i flused all the shit out and when i was filling it back up it didnt seem like coolant was moving through the system at all. i think it might be clogged somewhere
Old Nov 17, 2005 | 07:44 PM
92b18hatch's Avatar
92b18hatch
any other hints?
Old Nov 20, 2005 | 12:07 PM
92b18hatch's Avatar
92b18hatch
nevermind its all betttterrrrrrr
Old Nov 21, 2005 | 08:51 AM
JimBlake's Avatar
JimBlake
Sorry I was away for a bit. What did you end up doing to fix it?
Old Nov 21, 2005 | 10:35 AM
92b18hatch's Avatar
92b18hatch
let it just about over heat and then it burped. kinda scared me but its all good now.
