Maintenace Required' indicator showing red
Old Sep 10, 2005 | 06:50 AM
sibsankar's Avatar
sibsankar
Default Maintenace Required' indicator showing red
Honda Civic 2000 4-door --- My 'Maintenace Required' indicator showing red colour now. Earlier it was showing yellow. I have done 15 check in walmart which includes oil change+lub+ ...etc but still showing red indicator. Would appreciate if anyone can put any advise = >> sibsankar_c@yahoo.com
Old Sep 10, 2005 | 06:53 AM
teg92's Avatar
teg92
WHAT OK YEAH!
when was the last time you gave your car a complete tune-up? How many miles on it?
Old Sep 10, 2005 | 09:33 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
File Type: jpg
Old Sep 10, 2005 | 11:37 AM
Special K's Avatar
Special K
That's the fucking funniest thing I've seen in a while..... I'm currently laughing hysterically............
Old Sep 29, 2005 | 08:51 PM
C2daIzZle's Avatar
C2daIzZle
see the little square indention on your instrument cluster? put you key in it & push down, all it is from green to red is a 3000 mile odometer check, push that square roller button down to rest the 3000 mile counter.
C2daIzZle's Avatar
C2daIzZle
however, im waiting on mine to turn red to match a amber instrument cluster (:
Old Sep 30, 2005 | 05:37 AM
Integral's Avatar
Integral
Nightmare Motorsports
Bahahahahaha
Old Sep 30, 2005 | 06:09 AM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
several ways..
you can take the bulb out..
or you can hold down the little button on the gauge cluster, and put the key ignition into ACCII for 15 sec, and it will blink. and turn the key off and out of the hole.
let go of the button, and put your key back in the hole, now your maintence system timing should be reset.
