Shaving Honda Emblem
Old Jul 23, 2005 | 02:32 PM
Black95Accord's Avatar
Black95Accord
Default Shaving Honda Emblem
I was wondering how I could take off my rear Honda emblem and then somehow cover the two holes, or fill the two holes in, so that you cannot see that there was ever an emblem there.
Thanks
Ryan
Old Jul 23, 2005 | 05:37 PM
gasper44's Avatar
gasper44
Thanks
Ryan
Remove emblem and then use bondo filler and fiberglass resin to fill in the holes. Repaint, DONE
Old Jul 24, 2005 | 09:36 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Weld up the holes. I've heard sometimes the bondo falls through.
Old Jul 24, 2005 | 10:20 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
On small holes like that, it won't even be a problem. Just do what gasper44 said.
Old Jul 25, 2005 | 12:08 AM
Altern8r's Avatar
Altern8r
ye i agree do what gasper44 says as if you weld you will remove paint on the inside double skin and just cause it to rust eventually.
Old Jul 25, 2005 | 04:57 PM
Black95Accord
Thanks
Old Jul 25, 2005 | 07:15 PM
getter's Avatar
getter
Default I'm just asking because I'll be plugging up minor things on the bumper etc.
First fill up the holes with bondo filler and once that dries spread the fiber glass resin over it then sand over it for smoothing then repaint?
Am I correct?
Old Jul 26, 2005 | 08:04 AM
Altern8r's Avatar
Altern8r
ye getter that would be right so that you get a nice smooth finish. dont forget to prime it
Old Jul 26, 2005 | 09:35 AM
gasper44's Avatar
gasper44
Am I correct?
Thats how to do it, basically, your BONDO FILLER is the cake, your FIBERGLASS RESIN is the frosting.
Thats how it works though, never finish off holes just leaving bondo, cover it up with fiberglass resin which isnt subject to getting wet, once bondo absorbs any water etc, it will deform and crack. The fiberglass keeps a shell over it basically keeping it in shape and perfect.
*Im new here, but not in the car field. lol
Old Jul 26, 2005 | 11:12 AM
tonysstudio's Avatar
tonysstudio
when i did mine,my car was getting repainted in 2 weeks so i shaved the emblem and primered the area. i then used a second color and held the emblem in the area and sprayed the emblem back on. i did not care, it was getting painted. soooooo many people liked that for some reason.
