94 honda civic 1.5
Old Jun 26, 2005 | 07:38 PM
bigdogstown's Avatar
bigdogstown
Default 94 honda civic 1.5
where is the fuel pump and has any one put on a blaster coil and msd cap and is the fuel pump hard to install
Old Jun 27, 2005 | 03:45 PM
Honda3002's Avatar
Honda3002
I've put a msd rotor and cap on my old 95 civic 1.5L with a SS blaster coil. It is NOThard to do just take your time.
Some supplies needed 1st 3 feet of double wire of about either 20 or 18 guage wire. Some silacone either ( dries )clear or blue atv silacone.
1st thing is take off the spark plug wires one at time and mark them where they go on the cap.
2nd take the distributor off the head there will be 3 bolts to remove. I think it was either a 10mm or 12mm socket for the bolts.
3rd remove the cap,then remove the coil out of the distributor. make sure to mark the wires which is + and which is - on the coil. If I remember right the black wire with a yellow strip is the - negative wire for the new blaster coil.
4th Now is where a little skill comes in to play. you while need to figure out where to drill the whole in the distributor for the new wires for the new coil. I would suggest that you drill the whole so it pointing down toward the engine block. Before you do the final install of the distributor you use either blue atv silacone or some clear silacone. This is so water or moisture does not get in the distributor. Don't forget to replace the rubber O ring on the distributor.
Old Jun 28, 2005 | 01:13 PM
94civicdxcoupe's Avatar
94civicdxcoupe
Pimp Hand Strong
the fuel pump is under your back seat...only about 5 bolts holding the cover on and its under there.
Old Jun 28, 2005 | 07:32 PM
raiden571's Avatar
raiden571
turning u inside out
why are u putting in a blaster coil
Old Jun 30, 2005 | 09:36 AM
mberndt's Avatar
mberndt
LOL, why are u putting that on a 1.5L? Just keep it completely stock or swap it, don't waste ur money...
Spend the money on GSR leather seats, they are real comfortable
Later,
Mike
