Need Help with VTEC / Check Engine Light
Old Jun 24, 2005 | 07:39 AM
deadi16's Avatar
deadi16
Springfieldcivic
Default Need Help with VTEC / Check Engine Light
I just had my ECU chipped to have the VTEC kick in at 4800 RPMs. When I reach this, the VTEC does kick in, but the check engine light goes on. However, when I turn the car off and start it again, the check engine light is gone.
When my VTEC kicks in, it seems like there is a loss of power. It sounds loud but the car instantly stops accelerating as quickly as it did before the VTEC kicked in. Could the problem be a bad VTEC solenoid?? If it is all in my head and the VTEC is fine, what is the check engine light for??
Old Jun 24, 2005 | 07:46 AM
shivers's Avatar
shivers
Moderator Alumni
What car? What engine? What mods? I would guess the cross over is set way too low, but it's hard to tell without additional information related to your car.
2005 s2000
Old Jun 24, 2005 | 07:52 AM
deadi16's Avatar
deadi16
Springfieldcivic
Sorry
93 Civic EX
1.6L VTEC
Intake, Exhaust, Header, Hotwires
Old Jun 24, 2005 | 02:08 PM
deadi16's Avatar
deadi16
Springfieldcivic
i just checked it it's code 21, which is the vtec solenoid spool now what do i do???
Old Jun 24, 2005 | 04:04 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would pull the solenoid off first and check and make sure the filter is clogged.
Old Jun 24, 2005 | 06:39 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
knock senor
