CTR bushes
Old Jun 22, 2005 | 12:29 PM
lawrencehf's Avatar
lawrencehf
Default CTR bushes
Can anyone help me sust out which urethane kit to get for a 1999 Civic Type R JDM, I have contacted Energy suspension and Prothane and neither can help cause it is not an American market car. Cheers
Old Jun 22, 2005 | 07:45 PM
civicexstacy00's Avatar
civicexstacy00
They should be the same as the 99-00 Si bushing kit.
Old Jun 23, 2005 | 12:55 PM
lawrencehf's Avatar
lawrencehf
It makes sense but nobody could confirm, my only reservation is cause alot of the running gear is the same on the CTR as it is onthe ITR like the fact that it is a 5 lug suspension and even the calipers are the same. And yet the Si and the ITR have different part nos for the bush kits.
Old Jun 23, 2005 | 02:52 PM
civicexstacy00
Well, here's the deal, I really don't think they used different A-arms/control arms for the CTR (so the bushings should be the same there). Also, if you are looking at doing the motor mount bushings they should be the same as well as the mounts and mount points are all the same. The only thing that would really differ, suspension wise, between the Si and the CTR would be the spring/damper rates as the CTR was tuned for racing.
Old Jun 24, 2005 | 03:31 AM
lawrencehf's Avatar
lawrencehf
I think you are right, there is one basic difference for sure though, that the CTR has 26 mm front and 22mm rear antiroll bars. I will beordering the kit and will let you know when i try fitting.
Cheers and thanks for your help
Old Jun 24, 2005 | 06:42 AM
civicexstacy00
no problem man.
