95 Odyssey Radiator Replacement Question
Old Jun 21, 2005 | 08:36 PM
panam8's Avatar
panam8
Default 95 Odyssey Radiator Replacement Question
1995 Honday Odyssey Radiator Replacement
1) Do I Need To Disconect The Transmission Fluid Lines In Order To Replace The Radiator ?
2) How Long Should This Job Take? (replacing The Radiator)
Thanks For Your Help !!!
Old Jun 21, 2005 | 10:55 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
First off... :slap: Why the duece did you make another thread for this? Its the same topic as the other thread you made 30 minutes before!!
Secondly, I don't know how to do it but heres a :slap: for the road. Questions in this catagory take time to get answered.
Last of all. I just realized, this shouldn't even be posted in the DIY section. It should have been asked in the forum for your car..
Old Jun 22, 2005 | 03:12 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Shouldn't take too long at all. Remove all the coolant hoses (after draining the radiator of course), remove the fans and then remove all the bolts holding it in. Then pull it out and put the new one in.
I don't know about the transmission lines. Do they run into the radiator?
