DIY Strut bars? Possible?
Old May 3, 2005 | 08:58 AM
JoshJ's Avatar
JoshJ
bang bang.
Default DIY Strut bars? Possible?
Hey,
I was just pondering for a little bit. Would it be possible to create a strut bar if you had the correct measurements needed? I mean, could you go out, get some strong metal pieces, cut them into the correct sizes, and have a shop weld them together for you? Maybe I'd be easier just to buy one, but do you guys think its possible?
Old May 3, 2005 | 10:06 AM
Outxider's Avatar
Outxider
X-Motoring
its possible and i seen it done before. this is how benen industries started out.
Old May 3, 2005 | 11:35 AM
JoshJ's Avatar
JoshJ
bang bang.
I may investigate this a lil more. next time im at home depot, ill see what kind of metal tubing they have
Old May 3, 2005 | 12:28 PM
raiden571's Avatar
raiden571
turning u inside out
i have access to tig welders and plenty of stainless steel. i might start making some this summer if i have the time and sell them. it will be a one piece design if i do make it, similar to the mugen one in looks tho
Old May 9, 2005 | 04:56 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
hmm...to be honest with you I rather spend the 30$ for the oem gsr strut bar or get a type r replica then buy a homeade strut bar....thats just me though. If you end up doing it though goodluck!
Old May 10, 2005 | 05:07 PM
raiden571's Avatar
raiden571
its just steel man. and any replica bar will suck balls because it has those damn pivot points on them. a solid design is the only kind that makes a noticable difference
Old May 13, 2005 | 01:14 PM
Bricks2k4civic's Avatar
Bricks2k4civic
your best bet is to cut a rather thick sheet of steel to fit over the strut bolts on each side. Leave a space on the end long enough to weld square tubing to. Make the custom strut bar out of square steel tubing, weld everything together, and viola. That should probably work better than any generic strut bar with moving parts.
Old May 20, 2005 | 04:36 PM
civicandtegra's Avatar
civicandtegra
i know a guy who makes em, its no problem if u have basic welding skills u can do it
