Need Help?
Old Mar 16, 2005 | 12:46 PM
jdacura666's Avatar
jdacura666
Default Need Help?
Any Questions Please Ask Been A Tech With Acura Since 1986 Be Glad To Help Ya.
Old Mar 16, 2005 | 07:10 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I don't know if this thread belongs in this forum, but I will ask anyway...
I have this shaking issue that I can't seem to troubleshoot and eliminate, so I will see if you have any suggestions: While going about 40mph to 75mph, anytime I accelerate, the whole car shakes. It only happens when accelerating though, so I am thinking it may be an axle. I changed my drivers side about 6 months ago and recently changed my passenger side and the problem persisted. Tires are balanced and alignment is correct. Brake rotors are brand new as well. I discovered two broken motor mounts that I replaced and the problem was still the same. So I am thinking that the drivers side axle that I installed has a blown inboard CV joint, so I ordered a brand new axle to see if that fixes it. I am totally out of ideas and if that doesn't fix it, I will be forced to take it to a mechanic. I have tried every suggestion that people have given me but nothing helps. Maybe you have some fresh ideas that I can try before I take it in. Problem is, my previous mechanic won't work on my car at all now since I installed the turbo, so I am forced to take it to a high performance shop that totally gouges on the prices. Any help is greatly appreciated.
Old Mar 30, 2005 | 05:00 PM
Mikerike's Avatar
Mikerike
jdacura666,
your offer of help would be appreciated.
I have A 1994 Integra with left side damage.
I need inform on trailing arm and associated pieces.
Please reply
Mikerike
Old Mar 30, 2005 | 07:59 PM
fac90's Avatar
fac90
Question on front wheel bearings.
Is it dangerous to drive on bad front wheel bearings ? Its not like the wheel can seperate, right, or it can happen.
Old Mar 31, 2005 | 12:47 AM
Kestrel's Avatar
Kestrel
Push to shock!
I can answer that one. If your wheel bearings seize, you could potentially damage a lot of components. It becomes pretty expensive the fix then.
Old Apr 6, 2005 | 12:58 PM
freddicoe's Avatar
freddicoe
i"m working on a 93 accord for someone. he had an 02 sensor installed about 2 months before it died,i changed plugs,wires,cap and rotor .the car tried to start twice i think ,only to die within seconds. theres lots of fuel presure to the injectors,theres spark,theres carbon on brand new plugs.i"m looking for help on this one. I still need help on this. is there no help out there?
Old Apr 20, 2005 | 07:42 PM
Nelson's Avatar
Nelson
Administrator
You offer to help.... but....
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Apr 20, 2005 | 07:49 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Exactly... :squint:
