Help wanted: No more ventilation 90 integra
Old Feb 1, 2005 | 10:11 AM
foosaddict78's Avatar
foosaddict78
Default Help wanted: No more ventilation 90 integra
Here is my problem: There is no more ventilation...
What could be the cause of this problem?
How can I fix it myself?
Thanks
Old Feb 1, 2005 | 10:39 AM
12yearhondatech's Avatar
12yearhondatech
what do you mean?
Old Feb 1, 2005 | 11:08 AM
foosaddict78
the fan that pushes air in the habitacle of the car seems to be dead
Old Feb 1, 2005 | 03:16 PM
12yearhondatech
Its called a blower motor. it is underneath the passenger side off the dash behind the glove box. Take a small hammer and with the blower motor in the on position tap the blower motor with the hammer a few times if it starts to run then the brushes are bad in the motor you will need to replace the motor. You possibly could have a bad fan speed switch, Try taking some compressed air and blowing it through where you move the blower switch from side to side then spray some WD-40 in the same area and move the switch side to side several times.
Old Feb 1, 2005 | 05:03 PM
foosaddict78
thanks, I will try it tomorrow
