stalling
Old Jan 31, 2005 | 08:34 PM
diggy's Avatar
diggy
Default stalling
bought 87 accord. won't start occassionally/stalls rplcd distributor cap/ rotor. having battery/alt tested tommorrow. any clues as to what's wrong
thanks
Old Jan 31, 2005 | 08:43 PM
12yearhondatech's Avatar
12yearhondatech
What does it do when it stalles. When it stalles are the red lights still on, on the dash if not then it is a pigtail problem, the electrical part of the ignition switch. What is the idle rpm at? does it stall at idle or at speed? It is comin for the pcv to go bad and cause a big vaccum leak i have also seen the igniter go bad in the distributor.
Old Jan 31, 2005 | 09:07 PM
diggy's Avatar
diggy
it stalls at lights/ rounding corners. don't know about idling speed. whar is pcv? also do you know what pcm-fi light is for and why word brake light comes under picture. read your bio. sorry about ur back
