88 crx fuel pump
Old Dec 29, 2004 | 09:14 AM
LiquidBiohazard's Avatar
LiquidBiohazard
Default 88 crx fuel pump
Can anyone guide me as to where I can locate fuses related to the fuel pump? My fuel pump doesn't seem to be turning on anymore so the car wont start. I already tested the main relay and its working fine, but im not getting any response from the fuel pump. I'm new to the DIY thing and am not positive that the fuel pump is dead. Could it just be a fuse? So, can someone please tell me where all the fuses related to the fuel pump and fuel injectors are? have any ideas as to what it could be? thanks for your help
Old Dec 29, 2004 | 11:56 AM
VPUPPY's Avatar
VPUPPY
you can try your owners manual for a listing, but i think the fuel pump fuse should be inside the car. keep in mind that a car that old may have just have a bad fuel pump.
Old Dec 29, 2004 | 12:13 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I suggest you pick up a helms or service manual for your car if you are planning on working on it yourself.
Old Dec 29, 2004 | 12:49 PM
LiquidBiohazard
ok thanks, i did pick up a service manual for my car. ill poke around it and the cars manual and see if i can find anywhere in there. thanks
