which one should i get first an exhaust or an intake?
Old Dec 25, 2004 | 10:45 AM
oudi's Avatar
oudi
Banned
Default which one should i get first an exhaust or an intake?
which one you think is better to get first and if its an intake do i have to get an exhaust
Old Dec 25, 2004 | 11:18 AM
If you get one you might as well get the other....The whole system depend on each other to get the max efficiency out of a car.
it really depends on how much money you have also on which one to get first. I myself got an intake first then a week later received my Apex N1 exhaust system.
Old Dec 25, 2004 | 06:37 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Intake
Old Dec 25, 2004 | 07:19 PM
ED9man's Avatar
ED9man
driver
Pull all the resonator and air pipe shit off of you stock intake so there's nothing before the air box and get a header. If you have money left over pull out your stock airbox and hose clamp a K&N filter that has the right diameter inlet to the end of it. Good as any intake IMO.
Old Dec 26, 2004 | 07:32 PM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
Intake.
It's best with both, but if you are chosing just one, do the intake.
I'm guessing you have the D16 in your car and the VTEC on that SOHC engine is on the intake lobes.
Old Dec 26, 2004 | 08:13 PM
Honda3002's Avatar
Honda3002
No me I would go with a set of 4-2-1 header's first after that remove almost ever restricting stuff on the exhuast system.( Unless you are getting a turbo )Cat back exhuast first 2'' to 3'' diameter pipe . I'm running 2 3/4'' pipe
Then get the aftermarket intake; New upgrade injectors ; then upgrade the spark plug wires to a low resistance set ; great aftermarket coil from MSD.
Old Dec 27, 2004 | 01:02 PM
chimchim's Avatar
chimchim
You're running a 2 3/4" exhaust with a 1.5 liter D15?
Old Dec 27, 2004 | 05:34 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Naw that new fuel system will bump it up to a 1.5.2
Just kidding :bigok:
