help a gal out PLEASE
Old Dec 15, 2004 | 01:25 PM
stephanie's Avatar
stephanie
Default help a gal out PLEASE
I am in need of some guidence. I have a 91 Acura Legden I need to install a new fuel relay. I can't find it I have the part. need alittle better detail as to where it is located. so I can replace it.
Thanks for the help
Old Dec 15, 2004 | 04:26 PM
ED9man's Avatar
ED9man
driver
Are you mechanically inclined?
What is a fuel relay?
Old Dec 16, 2004 | 06:25 AM
JimBlake's Avatar
JimBlake
Main relay?? I don't have a Legend, but Honda usually likes to put those relays above the left kick-panel. Look around the area above & left of the driver's left knee. You'll probably have to remove some trim panels...
Old Dec 16, 2004 | 08:54 AM
seansosmooth05's Avatar
seansosmooth05
or do wat i do look for a book on you car and it will tell and show you the locaton and how to test and fix ANYTHING on your car
Old Dec 16, 2004 | 09:22 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
The Helms manual would probably be the most thoroughly done book, but the Haynes is cheap and doesn't really help out all that much for some things.
You may find the answer you're looking for in the HAN somewhere.... although I don't think it has the most info on Legends.
Good luck for now. Maybe a Legend-head will pop up soon.
Old Dec 16, 2004 | 06:45 PM
VPUPPY's Avatar
VPUPPY
i would go with what he said. do you have the new relay already? if so, just look for one that looks similar to it. you may have to look hard cuz its sometimes kind of up there.
Old Dec 17, 2004 | 07:18 AM
JimBlake's Avatar
JimBlake
There's some live wires up there, too, around the fusebox. Once you find it, disconnect the (-) battery cable first, before mucking around with screwdrivers...
