i still cant find the damn thing!!!
Old Dec 8, 2004 | 02:00 PM
seansosmooth05's Avatar
seansosmooth05
Default i still cant find the damn thing!!!
i need to find the tack wire or some wire that will put out 12v (+0 if and only if the rac is running. i need it for my remot start alarm senser thing thanks to u all r alsome
Old Dec 8, 2004 | 06:24 PM
BetterBob's Avatar
BetterBob
Nobama
Just tap in to the fuse for the radio, it will give you 12 volts and will only come on with the car... or use a test light to find another wire with power..
if you want to be lazy (like me) just strip the wire from the device you want to use, and wrap the wire around one of the studs on the fuze (as long as the wire is pretty small) and then re-install the fuze... im sure most people on here would say not to do it this way though.
In that case you will need to splice a wire (any wire that is hot w/ the car on) i find that crimp connectors are the best for this type of install (just make sure you mash the connector real good)
hope I helped
Better_Bob
Old Dec 8, 2004 | 08:27 PM
VPUPPY's Avatar
VPUPPY
actually i believe the tach wire on remote start systems looks for ac not dc. you can test for the tach wire by setting your digital multimeter to ac voltage. what kind of car do you have? you can probably get it off the distributor and sometimes in the car. If you give the specific year and model someone probably can post it for you.
Old Dec 9, 2004 | 04:43 PM
seansosmooth05
ill try those and the radio thing will only work once the car is running cuz it cant put out current when the car is just on it can only do it when the car is running so the remot start knows the car is started
Old Dec 11, 2004 | 08:57 AM
seansosmooth05
um ya i have to post on this tackh finding busynes and some one said the same thing it might be looking for ac and i have a 1990 handa accord ex 4 door
ps. in the insall book if i read it right though i think it said 12v+ is outputed on the wire i am to hook up
Old Dec 11, 2004 | 09:26 AM
seansosmooth05
holy shit i think i might have got it cuz i think it did just need to get a (+)12v signal and i went to the inside fuse box tested the starter signal one and it does just that. now the only way to no if it works rifht is to try it out BUT how do i get the car to do a cold start or wat ever it is that makes the car not start on the first attempt so i can see if it will make a second attempt at the start if it does not start on the first try
Old Dec 11, 2004 | 09:31 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Pull off one of the plug wires and give it a go. It wont start, and the unit should try again.
Put the plug wire back on really really quick if you want it to run on the second attempt.
