DIY ECU Chipping Kits for OBD0 / OBD1
Old Dec 3, 2004 | 06:25 AM
xenocron's Avatar
xenocron
Default DIY ECU Chipping Kits for OBD0 / OBD1
OBD1 ECU Chipping Kits - Good for Uberdata, Crome or buying one of those aftermarket EBAY chips and sticking it in (YUCK!)
OBD0 ECU Chipping Kits - Good for TurboEdit and again those sucky chips.
Good prices, fast shipping. Hope this makes it easy for the Do-It-Yourselfers out there to start chipping their own ECUs
I also donate a portion to the respective editors and pioneers that made this all happen. This is not a grand money making venture by any means
Uberdata
TurboEdit
PGMFI.org
Old Dec 6, 2004 | 09:05 AM
SurfNSB's Avatar
SurfNSB
The pre-burned programs that you can get. . . are those like base programs you can just use to get your car started and running and have a start to tune from?
Old Dec 7, 2004 | 08:58 PM
xenocron's Avatar
xenocron
Exaclty...the basemap will allow you to start and run the car. Many times the tunes are very close as they are base of the stock Honda maps and just rescaled for larger injectors and maybe a tweak here or there for other parts of the setup that allow more airflow.
Honestly most people that are getting these want to make their own basemaps as they are very DIY oriented...but some want a map they know that works for their first start-up after they chip the ECU.
Old Dec 8, 2004 | 07:26 AM
SurfNSB's Avatar
SurfNSB
I'm in the process of putting together a turbo kit. When I get to fuel management i'll definitely hit you up.
Old Dec 9, 2004 | 06:07 AM
Dan GSR's Avatar
Dan GSR
do you have the smaller chips for the JDM P30 ecu?
Old Dec 9, 2004 | 08:13 AM
xenocron's Avatar
xenocron
I dont yet, because there just isnt a huge call for it.
next time I place a supply order though...if you want to pre-pay and dont mind waiting a little, i will include the part you need, and make a 'kit' for you
im very flexible if you can be
Old Dec 12, 2004 | 03:48 PM
xenocron's Avatar
xenocron
Ttt
Old Dec 20, 2004 | 06:55 PM
xenocron's Avatar
xenocron
Now that its getting colder...this is something you can do inside, and still be working on your car
Old Dec 26, 2004 | 09:27 AM
xenocron's Avatar
xenocron
I have write-ups on my site to help you learn a little more about TurboEdit.
http://www.xenocron.com/te
If you are interested in Uberdata, Keebler65 has good stuff posted.
http://home.mn.rr.com/keebler65/honda/
Old Jan 20, 2005 | 06:52 PM
xenocron's Avatar
xenocron
TurboEdit now has support for a 2.5 BAR Map sensor.
