Is removal of rear window defroster possible??
Old Sep 23, 2004 | 08:39 PM
Inacurals's Avatar
Inacurals
Honda Hoar
Default Is removal of rear window defroster possible??
Is removal of rear window defroster possible?? Mine is busted by previous owner somehow. Id like to remove all the ugly orangish lines accross and around hatch window if thats possible to have a somewhat clear view outta my rear window. Lameass coments like "i wouldnt do that, or thats illegal or thats a reason to get pulled over" should be kept to oneself at all times. thank you.
Old Sep 23, 2004 | 08:48 PM
relecom's Avatar
relecom
Nissan 240
I would try using one of those razor blade scrapers, and try to shave it off. That might do it. it shouldn't be that difficult to scrape it off with a razor blade.
Mark
Old Sep 24, 2004 | 05:19 PM
96GreenCivic's Avatar
96GreenCivic
Interesting idea. Can't you fix it to make it work?
Old Sep 24, 2004 | 07:44 PM
relecom's Avatar
relecom
Nissan 240
yes you can. if the lines look something like this ________ ___________ throughout the back window, there are kits that you can get at automotive stores, and basically all it is, is a bottle with liquid metal in it, much like whiteout. and you paint it on to connect the lines.
Mark
Old Sep 24, 2004 | 09:06 PM
relecom's Avatar
relecom
Nissan 240
I forgot to mention this, but I have used those kits before, and I found the best way to apply the stuff was to mask off each line that needs to be repaired, so that you can paint the stuff on and after you peel the masking away you get a nice crisp line... FYI.
Mark
Old Oct 20, 2004 | 06:00 PM
96GreenCivic
Mark
I should look into that. Two of my lines aren't working.
Old Oct 20, 2004 | 06:02 PM
relecom's Avatar
relecom
Nissan 240
They work quite well, and the kits are about 9-10 dollars,
Mark
