Civic only starts if i unplug the main injector
Old Sep 8, 2004 | 03:53 PM
hawneh's Avatar
hawneh
Default Civic only starts if i unplug the main injector
This one has me stumped. The car is an 89 Civic with dual point injection. It will only start with the main injector disconnected and will then continue to run without it. It will also run if I then reconnect the main injector.
Anybody got any ideas what the problem is?
Old Sep 9, 2004 | 06:17 AM
JimBlake's Avatar
JimBlake
Maybe the other injector is stuck open?
Old Sep 21, 2011 | 07:45 PM
Nasif's Avatar
Nasif
Hi Hawneh, Can you please tell me what the problem was in your car. I'm sure you already figured it out and fixed the problem. My 91 Honda Civic Hatchback is doing exactly the same thing. Thanks a lot in advance.
Old May 25, 2025 | 09:31 AM
daryelcorran's Avatar
daryelcorran
Old Jan 30, 2026 | 01:33 PM
happy2bdaddy2's Avatar
happy2bdaddy2
Default I unplug my injector motor clears up
Im havingnproblems with my 94 integra 1.8 ls. When I unplug no 2 injector motor clears up. Brand new Injectors,timing belt,dist.,plugs, valve adjustment etc. But it was doing this b4 all that im pretty sure . Maybe ecu?
Nasif
Do It Yourself
Sep 23, 2011 08:05 AM
bnuk
92+ Civic/EL & Del Sol
5
Jul 29, 2005 09:06 PM
gunnar
CRX & Pre 92 Civic
2
May 11, 2005 05:30 PM
deepee15
6
May 8, 2005 10:43 PM
Jigga JJ
CRX & Pre 92 Civic
2
Mar 17, 2004 08:14 PM
