Removing Engine
Old Jul 18, 2004 | 08:53 PM
dustimus's Avatar
dustimus
Better golfer than you
Default Removing Engine
I'm goin to be removing my engine this week and my HELMS doesen't come till thursday. So i was wondering if anyone had a good write up on removing a B-Series from its' shell. Or if anyone has some quick steps, i've already took all the manifolds off and disconnected the fuel system. I want to save time before I get my Helms
Old Jul 19, 2004 | 04:03 AM
Kai's Avatar
Kai
Rotorphile.
Well, if you already have the manifolds off, pretty much the only thing left is the axles and mounts. Remove the axles, connect the engine lift, and begin removing the mounts. Easy as pie.
Old Jul 19, 2004 | 06:54 PM
ExiledinIN's Avatar
ExiledinIN
http://www.c-speedracing.com/howto/b18cswap/swap.php
It's pretty close to what you need to do. The cotter pin for the shift linkage I used a air hammer that got it started out of the hole.
Air rachet for the 32mm spindle nut is a plus!
