Bolt-outs not working for me...
Old May 12, 2004 | 05:24 PM
Big Chaze's Avatar
Big Chaze
Mr Clutch
Originally Posted by Josher
NOT true. I was at Home Depot yesterday buying a toilet Korky aka actuator and saw a set of bolt outs (I forgot the brand) that were not craftsman.
I could be wrong...but Craftsman are the only ones I would buy...
Old May 12, 2004 | 05:33 PM
Josher's Avatar
Josher
Believe me, these were generic Home Depot Bolt Outs. Regardless, I definitely agree with you on only buying the Craftsman.
Old May 12, 2004 | 07:55 PM
kiddo118's Avatar
kiddo118
I have hammered the bolt outs onto the bolts before and they are pretty damn tight after it's hammered. But once I start to unscrew it, the bolt-out just slides right off like it's unable to maintain the grip which brings me back to stage one. I would not recommend bolt-outs to anyone.
Old May 13, 2004 | 03:13 AM
Josher's Avatar
Josher
Have your tried heating the bolt, then using Vice Grips or a giant pair of channel lock pliers? Sounds to me like you might not have the right size bolt out.
Old May 13, 2004 | 06:35 AM
kiddo118's Avatar
kiddo118
I have the complete set of bolt-outs from craftsman including that carrying case that comes with it. I try to use the bolt-out that matches closely to the size of the bolt I'm trying to remove. I don't have a blow torch, vice grips, or channel lock pliers. Maybe I'll go get them if I find out I have too many rusted or rounded off bolts.
Old May 13, 2004 | 09:59 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
I think they're three different sets of bolt outs.
Your best bet is to buy a $20 dollar blow torch and heat that mother up.
Old May 13, 2004 | 12:28 PM
Josher's Avatar
Josher
Heat is the way to go. When using your bolt outs, are you using a ratchet or a wrench? A ratchet works best, since you can push the boltout onto the bolt while trying to torque it free. Get a torch. Where are these bolts at exactly and what do the hold?
Old May 16, 2004 | 11:18 AM
kiddo118's Avatar
kiddo118
These bolts sit under the rubber guard/lining beneath the car. There are two of these bolts that need to be removed in order to take off the bumper because the rubber guard/lining is attached to the front bumper.
RufusAZ
2
Jan 10, 2004 10:27 AM
AwwsChwA
Engine Swaps, Tech & Tuning
5
Jun 11, 2003 07:23 AM
Daniel
May 8, 2003 08:52 AM
Tinker Bell
9
Mar 21, 2003 01:53 PM
inspyral
7
Feb 4, 2003 11:59 AM
