Remote Starter!! Eek!
Old Jan 13, 2004 | 08:55 PM
vroom's Avatar
vroom
Default Remote Starter!! Eek!
well, right now i am installing it myself cause i am broke (how much is installation anyway?) and it says to connect 2 differnt power wires from the starter to the car 12 v constant wire........and well, i have installed just the 5 or 6 wires that are needed for the remote start, but when i hit the button, it doesn;t do anything......i haven;t installed any of the safety settings, but it should work....right.......also where would my neutral (somehting .......) not sure what its called, but its part of the safety stuff, and number 3....the thing for the brakes.....it is the wire that is connected to the brake pedal?
also, the 2 power wires to the constant 12 v wire, both wires just go to the 12 v wire? anythign special on it?
any tips on installing?
Old Jan 24, 2004 | 09:23 AM
98whiteintegra's Avatar
98whiteintegra
is your car manual or automatic?
Old Jan 24, 2004 | 09:22 PM
vroom's Avatar
vroom
car is auto
Old Jan 28, 2004 | 11:49 PM
phat99accord's Avatar
phat99accord
BMW Tech
what company remote start is it
the neutral saftey is needed, youre supposed to have a switch to a ground
basically when i do remote starts i just ground that wire that way the remote start is always enabled, when it doesnt see a ground then it will disable your remote start. hook up your brake switch, a word of advice if you dont and you connected a wire wrong say buhbye to your wireing possibly, if anything goes wrong u can disable it by hitting the brake which sends a 12V signal to the remote start
Old Jan 29, 2004 | 07:11 PM
vroom's Avatar
vroom
i have a ratller
i am thinking of having someone else install it........they might know whart they are doing?
Old Feb 1, 2004 | 06:13 AM
12volts's Avatar
12volts
Originally Posted by vroom
car is auto
Man! you can do it yourself. dont give up aight!! you dont have to worry about the neutral thing since you are installing it to Auto trans. just make sure you tap the right wires. wire that goes on the brake can easily found under where the brake bar is, just find the negative wire (-) If you have anymore problem just post!!
Old Feb 1, 2004 | 06:21 AM
12volts's Avatar
12volts
well, right now i am installing it myself cause i am broke (how much is installation anyway?) and it says to connect 2 differnt power wires from the starter to the car 12 v constant wire........and well, i have installed just the 5 or 6 wires that are needed for the remote start, but when i hit the button, it doesn;t do anything......i haven;t installed any of the safety settings, but it should work....right.......also where would my neutral (somehting .......) not sure what its called, but its part of the safety stuff, and number 3....the thing for the brakes.....it is the wire that is connected to the brake pedal?Yes! just make sure you hook it up to negative wire. (see wiring diagram of you car)
Old Feb 1, 2004 | 10:12 AM
vroom's Avatar
vroom
thanks for all the help, where can i find a wiring diagram for my car?
its an 03 accord
Old Feb 1, 2004 | 01:07 PM
12volts's Avatar
12volts
its an 03 accord
I just check 2000 Honda Accord its white/black, 2003 Model should be the same. Since it's a late model I'm sure it has factory alarm so you need to bypass that just so you know..you can find or buy it from 12VOLTSHOP they carry 3 item for your car... Goodluck man!!
