ECU CODEs
Old Jul 18, 2003 | 12:57 PM
CRXDOHCVTEC's Avatar
CRXDOHCVTEC
Default ECU CODEs
I have a b16a in a crx... and the Ecu is Blinking Code. i just wanted to know if anyone know what the code mean and what can i do to fix it.
the first blink is 2 fast Blinks?
the second blink is 6 fast blinks?
anyone have an idea what it means?
Old Jul 18, 2003 | 03:03 PM
Kai's Avatar
Kai
Rotorphile.
"2 O2 Sensor "B" (O2) Open or Short in O2 sensor circuit, bad O2 sensor Cat. Converter"
Code 2 means the secondary 02 sensor. If you have one, its bad or disconnected. If you don't, you have the wrong ECU.
"6 Coolant Temperature (TA) Loose or dirty connection, Short or open in circuit, Bad sensor - More Head, under distributor "
Code 6 is the Engine Coolant Temperature Sensor. This is often forgotten and left unplugged, it is on the distributor side of the engine screwed into the block, below the head.
Old Jul 21, 2003 | 09:46 AM
CRXDOHCVTEC
the Coolant Tempature is pluged in? can it be because its a bad sensor?
Old Jul 21, 2003 | 03:45 PM
Kai's Avatar
Kai
Rotorphile.
Disconnected, bad sensor, short in the line, etc.
