engine light
Old May 19, 2003 | 09:50 PM
pulse_crx's Avatar
pulse_crx
Default engine light
this has happened a couple times now, since i replaced my head gasket, engine light has come on while driving, doing like 90km in 4th. the light comes on and stays on, what does this mean? im new to ecu codes, so any help is apprieciated
Old May 20, 2003 | 07:08 AM
Old91CivicGuy's Avatar
Old91CivicGuy
check the flashes on your ecu
Old May 20, 2003 | 07:20 AM
JSpecMugen's Avatar
JSpecMugen
Default Re: engine light
Pull back your passanger side carpet to reveal the ECU on the floor. Watch the LED as it flashes. It will flash x times quickly and then pause for a longer period of time, then start flashing x times again. Count how many times it flashes quickly, then jot that number down. Do it a couple times over, just to make sure it's the same code and not another (If you're blowing more than one code, it will flash all the codes, then stop, and start from the beginning).
Take those numbers you took down and compare them to a ECU diag chart. Search on Google for honda ecu codes or something like to find the info on the codes.
Hope that helps! Let me know.
-JSpecMugen
Old May 20, 2003 | 07:41 AM
crxb16er's Avatar
crxb16er
http://www.crxsi.com/resources/manual/ecu_codes.htm
found this on the same site
http://www.crxsi.com/resources/CRX_concept/
check it out, doubt itd happen but id be the first one to hop all over it
