flywheel question
Old Apr 27, 2003 | 10:53 AM
geiser705's Avatar
geiser705
Default flywheel question
is the flywheel for 90 civic si 1.6 and DX 1.5 are the same?
I went to kragen and they told me its the same (205 Standard Honda Flywheel) but when i was searching for OEM parts on the interenet (like hondaautomotiveparts.com) dx have part nubmer 83439 or 83440 and si have 83441
Need advise please. We were tried to replace the clutch last night with new stock clutch but we were hearing grinding noise. Mechanic said that the flywheel might be in bad shape.
Old Apr 27, 2003 | 11:20 AM
doIhaveBDIs's Avatar
doIhaveBDIs
Banned
yea should i get a new fly wheel, with my new clutch? what will be the difference or should i just get my other one re-surfaced?
Old Apr 27, 2003 | 01:42 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
You can have your flywheel resurfaced but it can only be done so about .10'' or something like that so eventually you will require a new flywheel.
Old Apr 27, 2003 | 04:47 PM
crxb16er's Avatar
crxb16er
once they pull it all apart you will be able to tell, if the flywheel is jacked it is very obvious of abuse and wear otherwise itll be uniformly worn and not have major abuse
