Stuck
Old Mar 25, 2003 | 06:11 PM
Ryousuke Takahashi's Avatar
Ryousuke Takahashi
4G4D shortly a beast
Default Stuck
whenever i accelerate hard in first and second gear it's like the car shakes until you let off the gas but then it feels like it doesn't want to go anywhere when you get back on it.
Old Mar 25, 2003 | 06:13 PM
WhiteRice's Avatar
WhiteRice
Gotta start by asking the question that most will ask.....are you throwing any codes?
Old Mar 25, 2003 | 06:14 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
you feel any type of bog? check either:
1. Exhaust leak
2. distributor
3. spark plugs/wires
Old Mar 25, 2003 | 06:25 PM
Ryousuke Takahashi
nope not throwing anycodes it's probably 2 or 3
Old Mar 25, 2003 | 06:37 PM
ZiviCase10287
RacinMasonC
like when you drive it harder than normal, it'll start to shake all the way to redline? or just for a split second? if its until redline, try testing your spark plug wires, one or more may have a crack in it where it goes over the spark plug, if it does, replace wires....
steps that worked for me:
1: turn off car
2. have friend pull 1 spark plug wire out and lay it on the valve cover (metal)
3: let it sit on the cover and turn on the car, ask if he saw a spark come from where its not suppose to
4: repeat step 2 and 3 for each spark plug wire, but remember only leave 1 out at a time. and do NOT hold the wire. let it lay on the valve cover.
i'd try that, it should take more than 5-10 mins with another friend.. or you can go out and buy new wires hoping it'll work and you made a good choice on the buy... good luck!
Old Mar 26, 2003 | 12:26 PM
crxb16er's Avatar
crxb16er
yah probably a cylinder is out some how, either plug, plug wire. distributor issue check all those when it idles does it sound rough or is just during heavy acceleration? if its all the time check those if not write down exactly what its doing so we can help you out more
Old Mar 26, 2003 | 12:58 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
This can happen also if you have the wires reversed on your tps...
