apexi vtec controller.... help me!
Ok. I have A JDM 1ST GEN B16A engine, and I want to hook up my apexi vtec controller to my PWO ecu. I don't have a diagram or anything that tells me where to put what wires into the ecu. Is there anyone that has done this to a 89' crx si that can tell me what to do?
apexi problem
i have a crx 91 b16a engine with pwo ecu
and i need to know the wiring diagram of the ecu if someone could help pleasE!!!!:eek: |
http://b16a.honda-perf.org/wiring.html ...dont know if that's the right ecu but it might be...hope it helps
Apei
i need some help with the setup of the apexi vafc with the b16a engine ecu pwo ... and if some one please let me know where is the vtec wire signal in the ecu mufler ... and ore more question the setup of the apexi with a turbo how should i setup it.:eek:
apexi vafc
Hi i have a crx vtec pwo ecu and i have the same problem.... i dont know the ****ing wiring colors. does any one have a pwo ecu whith vafc instaled?? :confused:
APEX'i has the manuals for the VAFC and VAFC II on their website. Make sure you have Adobe Acrobat on your computer to read the .pdf files.
VAFC: http://www.apexi-usa.com/productdocu...onics_vafc.pdf VAFC II: http://www.apexi-usa.com/productdocu...ics_vafcII.pdf |
apexi vafc PWO WIRING DIAGRAM I HAVE IT
if you want the wiring diagram mail me to pereiravtec@oninet.pt
Apexi Vafc Wiring Diagram Pwo
1 Attachment(s)
Is This What You Were Searching For? :d
