This sucks
Old Dec 14, 2002 | 07:07 AM
Ryousuke Takahashi's Avatar
Ryousuke Takahashi
4G4D shortly a beast
Default This sucks
I figured out why my car wouldn't start it didn't have any water in the battery as soon as that was finished and i let it run for about 20min the check engine light came on do you have any ideas
Old Dec 14, 2002 | 07:25 AM
jaje's Avatar
jaje
HC Racer H5
pull up the carpet in the passenger kick panel and count the flashes the ecu gives (it flashes when the check engine light is [diagnostics])...if there is a longer pause that means its finished with the current number and is starting over
Old Dec 14, 2002 | 05:41 PM
Ryousuke Takahashi
never mind it went off.
Old Dec 14, 2002 | 07:11 PM
WhiteRice's Avatar
WhiteRice
The engine light goess off, but your ecu will save the code if there's a problem. I'd still recommend looking at the ECU for a code.
