Car is pulling to the right
Old Nov 1, 2002 | 01:56 PM
excitid's Avatar
excitid
Default Car is pulling to the right
I drove the wifes wagon today since she said it felt weird and when I start to brake it pulls sharpley to the right. I also noticed on the highway when I push the gas pedal it pulls a bit to the left and when I let go of the pedal it goes back to the right. I'm planning on doing ball joints, the right side tie-rod and the rear struts. Is there anything else you guys can think of.
Old Nov 1, 2002 | 06:19 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Maybe the left side caliper is broken.
Old Nov 1, 2002 | 11:56 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
I'd check the bushings too.
Old Nov 2, 2002 | 05:55 AM
excitid's Avatar
excitid
if I brake hard its less noticable but I noticed today that the left rotor has no screws in it would this make a big difference.
Old Nov 2, 2002 | 04:01 PM
jaje's Avatar
jaje
HC Racer H5
sounds like your left front caliper maybe getting stuck (theres a pin in there and if the system gets old or isn't maintained [flushing brake fluid]...it will cause the caliper piston to stick and not go fully back...this causes the pad to drag on the left rotor making it track left when not braking and causing it to pull right when braking since the right side is getting much better brake contact b/c the pad isn't worn as much as the left one
Old Nov 2, 2002 | 05:14 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Pulling right under braking and left on acceleration sounds like a suspension problem to me. Ball joints, shocks/struts, and bushings.
-Harry
AIM: NDcissive
