tranny noises
Old Oct 19, 2002 | 09:46 PM
slomo's Avatar
slomo
Default tranny noises
i get some annoying noises in between 2nd. and 3rd. gear. It sounds like a whine of some sort. please help me out, thanks.
Old Oct 19, 2002 | 11:07 PM
excitid's Avatar
excitid
I would recommend changing you tranny fluid. Do you have any grinding between shifts. I had a slight whining noise and I had the fluid changed and it was fine and actually started shifting better.
Old Oct 20, 2002 | 12:08 AM
AwwsChwA's Avatar
AwwsChwA
along with the fluid change, add some Lucas Oil into the mix. I had a very crunchy 3rd gear synchro in my transmission, and using a 20% Lucas Oil mixture with 10/30 motor oil, I all but eliminated the grind. You can get Lucas Oil at any Napa parts store. Use it in the engine, too, it's great stuff.
Old Oct 20, 2002 | 01:54 PM
BlackCRX's Avatar
BlackCRX
i say change the tranny fluid to but i wouldnt add anything additives
just run honda oem MTF
Old Oct 20, 2002 | 02:55 PM
WhiteRice's Avatar
WhiteRice
about 2 quarts of 10w30 will do the trick too.
Old Oct 24, 2002 | 08:36 AM
slomo's Avatar
slomo
i've got 10w40. will that do?
Old Oct 24, 2002 | 08:45 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
a whine? syncros are failing. theyre brass. if the new fluid dont fix its time for a rebuild.
