My 89civic project, with Q's and pics
4 Attachment(s)
i have some questions that im not sure of, im new to the older style hatchbacks. im still waiting for my shipment with the valve cover washers and gaskets to come in. later on today ill try to get my suspension set up pic. i bought this car for 375 bucks from some guy that didnt finish it..
it has a d15b2 trans, with a 1.6 motor is what he said.. i bought it to keep me busy thru the winter.. in the first pic on the manifold im lost to were to connect that open valve? second pic that silver box is that a fuel relay? Attachment 73145 Attachment 73148 |
the first pic i asked were to connect the middle open valve, and i looked on my 93 civic and it runs to a black plug thing, then under the manifold and it looks like the hose does not connect to anything?? im really confused does that valve need a hose?
May be the pcv fitting on the intake manifold.
first one is the vacuum source for the PCV system.
does it need a hose on it?
1 Attachment(s)
well what im trying to say is there is no pvc plug or valve w/e you call it in the manifold its missing there is a hole for it tho, in the pic i circled it.
Attachment 73149 |
Your second pic is your inj resistor box.
you sure its not for the vacum on the brake booster make sure ones going to that or the pvc system the one guy i think is right cause should be a hose under the #2 and # 1 injetor the goes though the intake mani then to father under the manifold behind
# 3 cyclender i think check that too |
#1 Pcv
The first picture is the vacuum draw for the pcv valve. You should have a hose that goes from there to a hole in the metal of the intake, the pcv is the black box looking thingy beneath there that connects to the opposite side of the hole in the metal.
Ditto
Originally Posted by daveb91
(Post 3707713)
| All times are GMT -8. The time now is 03:02 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
