timing question
Old Mar 5, 2007 | 09:40 AM
Slowking69's Avatar
Slowking69
Default timing question
this is just a pre-motor drop question. The motor is set to tdc the head pulley which says up is facing up. now the question is that of the dizzy is it supposed to be on number one and if im not mistaken number one on the dizzy is at the bottom left if your facing the dizzy placed on the motor
Old Mar 6, 2007 | 06:42 AM
jlicrx's Avatar
jlicrx
what engine?
Old Mar 6, 2007 | 07:23 AM
Slowking69's Avatar
Slowking69
its the single cam zc from a 91 integra or crx si. I beleive thats right but i just want to make sure i dont screwa anything up and the timing is right before i drop it in i really dont want any timing isues after its dropped
Old Mar 6, 2007 | 01:48 PM
theleprechaun's Avatar
theleprechaun
Default yea
Should be lower left, 1,4,3,2 (???) i believe.
Old Mar 6, 2007 | 05:43 PM
Slowking69's Avatar
Slowking69
Sweet i love it i read in the manuel the firing order is 1,3,4,2 clockwise from 1 of course. So im sitting at tdc my dizzy is on number one and the pulley timing mark is facing up sound good. now one final question. i put the motor at tdc with the head off not really sure how to determine which stroke its on. would this matter considering its not building up any compression with the head off or do i get to do this again to make sure im not 180 off.
Old Mar 6, 2007 | 08:32 PM
theleprechaun
dizzy should only
mount one way, has offset forks where they mount into engine, if its tdc u should have no problems
Old Mar 7, 2007 | 05:31 AM
Slowking69's Avatar
Slowking69
ill post some pics and let oyu know if the final product was a good turn out but i feal confident that itll work this is my first import build. i appreciate the help
Old Mar 7, 2007 | 01:41 PM
Slowking69's Avatar
Slowking69
one more question is there a timing mark on the crankshaft pulley that should be facing upward
