Performance gauges
Old Jan 8, 2007 | 12:23 PM
snider_Zeo's Avatar
snider_Zeo
Default Performance gauges
I'm not quite sure what to call them...... performance gauge, boost gauge etc. Sorry just a lil new. But which one of the three do you get. They have like 5-6 different ones that check the stats of diff engine parts oil, water etc. To put up on your 3 part pillar.
Also what guage is it, that tells you when to shift. I light comes and to show you?
advise
Old Jan 8, 2007 | 12:28 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
A shift light. Oil pressure and water temp are the most important things for you at this point. Unless you have a built motor, gauges are not a necessity.
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
um..unless you don't have anything done to your car...there is really no reason for you to have them.....the gauge that tells you your RPM'S and has a shift light is called a tachometer....judging from this post...u don't need one of those either
SEARCH SEARCH SEARCH
Old Jan 9, 2007 | 12:12 PM
snider_Zeo's Avatar
snider_Zeo
Thats it tachometer, im planning on swapping muh engine, so i guess i dont need the other gauges right? I do have an rpm gauge though. I've seen people with tachometers even though they had an rpm gauge. Whats with that.
Also which 3 part pill is the best to you guys. Like on the dash, top left door rim, etc?
Old Jan 10, 2007 | 07:26 AM
silvic00's Avatar
silvic00
rpm gauge and tachs are the samething, i dont know why
its all personal preference on gauge pod
Old Jan 10, 2007 | 07:21 PM
totalimmortal
MalleusMaleficarum
Aftermarket tach+stock tach=FTL!
Old Jan 20, 2007 | 05:55 PM
jdm498's Avatar
jdm498
I might get something like this if i wanted gauges.
http://www.42draftdesigns.com/products.htm
