90 crx si swap question??? help me out
Old Oct 2, 2002 | 12:47 AM
DAJDMJUNKY's Avatar
DAJDMJUNKY
chill factor performance
Default 90 crx si swap question??? help me out
i own a 90 crx si and i just got a brand new 2000 sohc vtec ex manaul engine with only 5k on it all for free..nice and clean with the computer... i know everyone is thinking why not the b18,b20,or b16.
truth is i wanna push the sohc vtec 2 test it out cause i know i can work it out..
my plans are 2000 sohc vtec
- bottle of zex
-apexi vtec controller
- intake
- staightpipe exhast set up ***custom welded as much as possible..
- fuel sytem the ignition system
the tuned and dynoed
have the ecu upgraded or use another one
this is were i'm lost guys.. help me out? what ecu can i use 2 run it or the best ecu and do i need motor mounts for this swap?
i also needed 2 know is what wriring harness do i use cause thats the only thing i didn't get from the swap??????
Old Oct 2, 2002 | 08:47 AM
DAJDMJUNKY's Avatar
DAJDMJUNKY
help a man out
Old Oct 2, 2002 | 09:59 AM
jaje's Avatar
jaje
HC Racer H5
Default Re: 90 crx si swap question??? help me out
- bottle of zex
- intake
use the sohc vtec ecu...it adapts to the wiring in your si...you only have to add 4 wires http://hybird.honda-perf.org and look up wiring for vtec on ef civic/crx
the sohc vtec bolts right in b/c it is a d series motor...doesn't require any modificaiton to fit
Old Oct 2, 2002 | 10:13 AM
DAJDMJUNKY's Avatar
DAJDMJUNKY
Default Re: Re: 90 crx si swap question??? help me out
thanks alot bro
Old Oct 2, 2002 | 10:15 AM
DAJDMJUNKY's Avatar
DAJDMJUNKY
that link u set bro isn't coming up for the wiring harness
Old Oct 2, 2002 | 10:17 AM
WhiteRice's Avatar
WhiteRice
You gotta navigate into the site to get to the harness
Old Oct 2, 2002 | 01:43 PM
ISP James's Avatar
ISP James
DAMIMRED
hey you also if you are usin the '00 tranny you are gonna have to do some converting... your crx is set up cable that tranny is hydro clutch.
Old Oct 3, 2002 | 06:26 AM
DAJDMJUNKY's Avatar
DAJDMJUNKY
where is the best place for me 2 look for this stuff bro, i'm gonna need the hydro tranny set up and what wiring harness??????????
