d16a6/ d16a1
Old Sep 19, 2006 | 06:19 AM
fixerupper's Avatar
fixerupper
Default d16a6/ d16a1
I have an 89 Integra with the d16a1 parts car, and my driver is CRX d16a6. I had heard that there were some swaps from the integra to the Si that work well. Could anyone point me in the right direction? I also wanted to know if the head off the d16a1 would fit the d16a6?
Old Sep 19, 2006 | 05:26 PM
Kai's Avatar
Kai
Rotorphile.
You can't use anything off of that car. The 86-89 Integra interchanges with the 84-87 Civics.
No, you can't use the head.
Old Sep 19, 2006 | 09:39 PM
Exempt's Avatar
Exempt
2 tone Rex
Yea, those engines are completely different... You couldnt even swap the DOHC A1 into the CRX without a huge headache (not too mention the work wouldnt be worth it in the end)...
The Integras ppl get their swaps from are the newer DA (90-93) and DC (94+) Integras with B series engines... A B series would definately be worth swapping...
Old Sep 23, 2006 | 04:30 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
You could take the A1 pistons and use them on your A6 for higher compression.
Old Sep 26, 2006 | 08:19 AM
fixerupper's Avatar
fixerupper
Ok, thanks for the info. So what do you guys recommend for a naturally aspirated swap? I really don't want to just turbo the thing.
Old Sep 26, 2006 | 08:48 AM
jaje's Avatar
jaje
HC Racer H5
there's lots of options - all depends on your budget (someone check on the obd requirements as I can't remember them correctly)
Cheap Upgrades (change engine but attaches up to the stock si transmission)
just replace the d16a6 engine - it has good power and uses the ecu
dohc zc swap 130hp, requires new ecu
d16z6 sohc vtec 130hp - requires new ecu and obd 1 conversion
d15b sohc vtec 135hp - requires new ecu and obd 1 conversion
More Expensive upgrades - have to get motor mounts to put these in
b16a1 or b17a (from 90-91 integra gsr) sohc vtec 160hp - requires b series cable transmission and ecu
b16a2 dohc vtec 160hp - requires b series cable transmission, ecu and obd 1 or higher conversion
b16b dohc vtec 170hp Civic Type R - same as b16a2
b18b - dohc non-vtec
b18c1 - dohc vtec integra gsr motor
b18c5 dohc vtec (ITR)
Even more expensive - have to make clearance
b20 - from cr-v non-vtec
crvtec motor (b20 block with b16/b18 dohc vtec head)
k20, k24
there's even been a v8 stuffed in a rex before...some guy has a crx with a nsx engine in the rear...
