sway bars
Old Sep 15, 2006 | 09:25 AM
tafkamb2's Avatar
tafkamb2
Default sway bars
who makes the best sway bar kit for a second gen crx?
Old Sep 15, 2006 | 07:43 PM
daddiodanger's Avatar
daddiodanger
bad mo fo
suspension techniques
comptech
neuspeed
blox
eibach
depends on what you want to spend
and you can find them anywhere
it's not so much whats the best but how little body roll you want.
most vary between 21-24mm and adjustability for the crx.
i have a suspension techniques sway bar kit. it really helps but i
prefered using the stock rear sway bar.
it personal preference.
Old Sep 16, 2006 | 08:19 AM
MTEng's Avatar
MTEng
Remember, too, that more roll stiffness will drastically affect the handling balance of the car. I'm not saying that's bad, just different. Make sure you have an objective in mind.... "better handling" is not only vague, but objective. Also, sway bars are only PART of the equation... bushings, alignment, springs, struts, etc all play a part.
For example, Auto-Xers (circa mid '80s, racing 3G/4G Civics) used to completely remove the front sway bar because they WANTED the body to roll. Some road racers would use 28mm (sometimes larger) bars.
For "spirited street driving" I prefer stock bars with slightly lowered (~3/4") springs and fully adjustable struts. I want compliance with a moderate amount of additional damping. daddiodanger nailed it.... too much rear roll stiffness can be a real handful on the street!!!!
Old Sep 18, 2006 | 12:51 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
For the street big front and rear bars for autox big rear, small or no front bar.
Old Sep 21, 2006 | 02:59 PM
zekezank's Avatar
zekezank
I like the neuspeed bar myself, it bolted up nice once I got it in. But that was one of the last things I did for handling, as the rest of my suspension was already finished, and I had the car lowered.
Lowering it probably made the biggest difference in handling I think, I haven't met a turn yet I couldn't take.
