cel help
Old Aug 28, 2006 | 07:07 PM
si-ripper's Avatar
si-ripper
Default cel help
i keep getting a code 17 but my speed cable is hooked up. can anyone help thanx
Old Aug 28, 2006 | 08:03 PM
ChrisS's Avatar
ChrisS
Check the wiring to the cluster. It could be just corrosion on the contacts. (use some electrical contact cleaner and a q-tip)
(my 1991 crx si was throwing the same code and I fixed it by fixing the ground to the cluster. The speed sensor is in the cluster on my car; not on the transmission.)
Old Aug 31, 2006 | 12:43 AM
si-ripper's Avatar
si-ripper
everything is clean, can the be cluster bad
