Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   CRX & Pre 92 Civic (https://www.honda-acura.net/forums/crx-and-pre-92-civic-8/)
-   -   Car won't start after camshaft install (urgent) (https://www.honda-acura.net/forums/crx-and-pre-92-civic/242677-car-wont-start-after-camshaft-install-urgent.html)
L3V3L Jul 15, 2006 03:48 PM
hey everyone
i have just installed a D16A6 camshaft along with an AEM Tru-Time cam gear into my D15B2(Mpfi). I just put everything back together and now my engine wont start. It will turn (camshaft and crankshaft), i have spark - but it just wont start...I also did a valve job on it aswell...any ideas?? any help will be greatly appreciated
trev
shivers Jul 15, 2006 08:25 PM
Go back and re-check your work. Make sure the timing belt is on correctly, the timing marks line up at TDC, and that the distributor is back in the original spot. Really inspect the timing belt and cam gear. When I built an engine for my last car, I had the exhaust cam gear (DOHC) advanced one tooth and didn't even realize it. Everything looked right and the car would run, I just couldn't get the timing within spec. Luckily I knew a guy that checked it over and found my mistake.
© 2026 MH Sub I, LLC dba Internet Brands
