Checking compression
Old Jul 14, 2006 | 10:35 AM
abarone300's Avatar
abarone300
Default Checking compression
Hi guys, wanted to ask if I would be able to check the compression with both of my cams off. I got a 1.6 LT dual oh VTEC/ '95 Del Sol
I'm removing the head to check if any of my valves are bent after the timing belt broke.
I did try to install a new belt, and the motor did run afterwords, but not too good though...
Had to advance the timing all the way, to be able to drive the car. I suspect I have low compression because of bent valves.
Also, do you guys know a way to get to the lower intake manifold retaing nuts (can't even get my hand in there to check!) Thanks
Aldo
Old Jul 14, 2006 | 10:39 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Thanks
Aldo
No
Old Jul 14, 2006 | 12:20 PM
abarone300's Avatar
abarone300
Default Thanks!
With both camshafts out, aren't all four valves on all combustion chambers closed?
If I where to remove the all four spark plugs, and alternatively hook up the compression gauge to each chamber, shouldn't I be able to measure compression when the piston is on TDC? Thanks
Aldo
Old Jul 14, 2006 | 12:28 PM
F22B Prelude
Rachel Bilson
You can't check compression without a corresponding compression stroke on the CAM....so you'll need to put them back on and test it.....If the valves are visibly bent then there is no reason to check compression
Old Jul 14, 2006 | 12:34 PM
abarone300's Avatar
abarone300
Default OK, Thanks
Ok F22B Prelude, I'll just remove the head then! Thanks
