wheel vibration
Old May 13, 2006 | 10:12 PM
judgeDredd's Avatar
judgeDredd
Default wheel vibration
i just got a b16 swap done in my crx and after only 120 miles i started to get a heavy vibration from the front end but only when i get on it and over 3g's when im just crusing it doesnt do it only when i accelerate any ideas what could be the problem?
Old May 14, 2006 | 04:39 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
motor mounts?
Old May 14, 2006 | 07:21 AM
judgeDredd's Avatar
judgeDredd
brand new motor mounts just got the swap.
Old May 14, 2006 | 08:29 AM
ChrisS's Avatar
ChrisS
wheel balance, alignment, worn suspension bushings, or worn front wheel bearing?
Old May 14, 2006 | 05:02 PM
dapump2003's Avatar
dapump2003
check your AXLE... you might of have busted you boot...LMK
Old May 14, 2006 | 05:49 PM
SirHybrid's Avatar
SirHybrid
could be the alternator rubbing the frame. Doubtful, but possible, if you didn't make enough clearance. Also, the b16 makes the ride quite a bit rougher than stock.
Old May 14, 2006 | 08:06 PM
judgeDredd's Avatar
judgeDredd
they made clearance for the alternator the motor didnt do it the first 100 miles and it only does it under acceleration i was hopeing that might be an indicator.
Old May 15, 2006 | 11:24 AM
Danpjack's Avatar
Danpjack
its wheel balance get it road forced. trust me my dad sells the machines that does it... if that doesn't work then u may just have some un even wear some where its more then likey the balance or road force
Old May 15, 2006 | 08:55 PM
judgeDredd's Avatar
judgeDredd
i took it in today and had the tires checked they were slightly off balance but not enough to cause the problem so they were rebalanced and it still does it just the same but now i cn cross that off from my list of posible causes.
Old May 22, 2006 | 01:34 PM
RedlineBoyzCRX
EG6
tie rods!
