Fuel Injectors-Which one is Primary and which is Auxillary?
I pulled a code off of my civic and I believe it's the fuel injector. Which one is primary and which one is auxillary? I only have two and one is located higher than the other.
thanks Bryan |
What year....you should have 4 injectors unless its that Direct Port fuel deal they had.
we need more info...what year and model Civic you have
for 87 and older many were carb'd still with the Si's having MPFI (4 injectors fed fuel in the intake manifold right before the valves - what standard fuel injection is now considered)...some other models may have had a fuel injection setup for 88-91 the dx, standard had DPFI (2 injectors fed fuel after the tb into the intake manifold)...the si and crx HF models came with MPFI standard you could have a dx wtih MPFI who a previous owner converted it over making it more confusing i'm not sure what you mean by auxillary |
Get MPFI and u wont have that problem. LOL
the upper one is Main
I have an 89 Civic DX 1.5 I believe it's the 2 fuel injector system
I have a 90 civic, same deal, duel point fuel injection, and the check engine light came on for fuel injector circuit malfunction.
Is the dual point system staged?
If DPFI computers run one injector up to a certain RPM, then cut in half bringing the second online to take up the other half... that would suprise me. Anyone know the flow rate of DPFI injectors? |
I have a civic 89. It has two injectors. upper one is primary and lower one is secondary. The when both injectors are pluged in car does not work properly and give black smoke and sometimes engine goes off, and does give give good mialage, but when I unpluged the primary injector, every thing works fine when check light is on. I wanted to know that Using my car with a secondary injector would effect engine or anything else? or it is fine?
