Car Engine Computer ECM
Old Nov 8, 2005 | 06:29 PM
Danpjack's Avatar
Danpjack
Default Car Engine Computer ECM
Hey I found out that My computer in my 1990 CRX Manual is shot the part number appears to be D930-101A
We arn't sure what engine is in the crx but the model number is: ZC 2414350
can any 1 help me out on where i can get a new computer that works with this engine
The computer that was in it was from dinan engeering
i can't find a web site for the company so i need some help please
Old Nov 8, 2005 | 08:38 PM
Exempt's Avatar
Exempt
2 tone Rex
That is a Jap spec engine... Do you know if its SOHC or DOHC? If its the DOHC, finding the exact ECU (more common than ECM in the Honda world anyways) is gonna be costly and hard to find... The original JDM ECU, and the best, that runs that engine is called the PM7, but as I said, its getting more and more hard to find... Good news is, you can run 2 other ECUs... A decent ECU to run on it is the PG7 from a US spec 86-89 Integra, and the US spec 88-91 Civic/CRX Si unit called the PM6, is also a decent unit, but its best to go with the PG7 or PM7...
So in this order:
PM7 = Best ECU to run the DOHC ZC
PG7 = Next to best
PM6 = Should work fine, but itll run a little lean (others will run a tad rich which IMO is better)
As for your Dinan ECU, those are even harder to find than the JDM ECUs... Reason is, they only made a few Honda ECUs, they normally do BMW parts (they found BMW enthusiasts 'more loyal' )... In fact Ive only heard of a few people whove had them...
Now if its the SOHC, I would think the best ECU is the PM6 from the US spec Civic/CRX Si...
And make sure u get the right one for the right tranny... If u have an auto, get an auto ECU, if u have a 5 speed, make sure its a 5 speed ECU...
Old Nov 9, 2005 | 07:45 PM
Danpjack's Avatar
Danpjack
wow you really know this stuff
i called a high proformance guy in cali and he said that its probly my O2 sensor THANK GOD!\
so i'm gunna try that and if that dosen't help then i'll get the computer
Old Nov 9, 2005 | 08:02 PM
Exempt's Avatar
Exempt
2 tone Rex
Nah, I just do alot of reading...
Old Nov 10, 2005 | 04:19 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
That's what I do all day. I read about this stuff.
Old Nov 15, 2005 | 11:04 AM
Danpjack's Avatar
Danpjack
i just found out that the o2 sensor helped but when ever u like shake it it starts to sputter again so i do need a new computer...does any 1 know were online i can get 1 or a place that i could call and order 1?!?!?
thanks
dan
Old Nov 16, 2005 | 10:46 AM
Danpjack's Avatar
Danpjack
No worries i got the new computer and the o2 senor is in i'm taking it to my guy tonight and i'll let you all know if its working...it should theres nothing else that could be wrong.
thanks for the help
Dan
Old Nov 21, 2005 | 10:50 AM
Danpjack's Avatar
Danpjack
i got a new computer out in and its running great thanks for the help...
i just ordered some KYB AGX Shocks...471.12 and my camber kits so now its on to the modification..
