Should I get an Oil Catch can
Old Oct 31, 2005 | 04:38 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Default Should I get an Oil Catch can
What is the point of an Oil catch can? Do I need one? I thought that only people with Turbo's needed them. Will it improve my performance at all?
Old Oct 31, 2005 | 02:15 PM
Kai's Avatar
Kai
Rotorphile.
No, you don't need one for a normal N/A engine.
Old Oct 31, 2005 | 11:18 PM
RevengeCRX's Avatar
RevengeCRX
89 CRX si, now with b16!
Aren't oil catch tanks designed to collect oil from the turbo, and keep it cooler....Sort of like a cold air intake for your oil?
Old Nov 6, 2005 | 01:58 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Oil catch cans are to catch oil vapor and/or oil blowby from the crank case, instead of feeding it back into the intake tract.
On a N/A car, they're really not necessary. I have one on my car, but only because there was no way to hook the PCV line up to my weber carbs.
On a boosted engine, a catch can is a good idea because it's pretty easy to pressurize the crank case and cause excessive oil consumption, especially if the PCV valve isn't working properly. The PCV valve is supposed to be a one-way check valve to keep the crank case at zero pressure differential, but as I said, if it's not sealing correctly in the closed position, then the intake tract could pressurize the crank case.
-Harry
AIM: NDcissive
Old Nov 7, 2005 | 04:08 AM
RedlineBoyzCRX
EG6
Guess I don't need one then. THANX
