knock sensor????
Old Sep 15, 2005 | 01:19 AM
crzy000's Avatar
crzy000
Default knock sensor????
to make this story short. My friend did a head swap from a non-vtech head to a v-tech z6 head. he even got the conversion harness from obd0-obd1. everything work's find but he keeps on having engine light on. we did a engine code reading and it gives us 23 which is the knock sensor. But as we all know that the non-vtech don't have any knock sensor on a d16a6 block. my question is; Is there any way to by pass the knock sensor so that the engine light will not go on?
Old Sep 15, 2005 | 02:34 PM
1fasthb's Avatar
1fasthb
What ecu is he running?
Old Sep 15, 2005 | 03:22 PM
crzy000's Avatar
crzy000
p28
Old Sep 15, 2005 | 11:01 PM
drkslayer's Avatar
drkslayer
take out the check engine bulb... hehehe
Old Sep 16, 2005 | 08:09 AM
Kai's Avatar
Kai
Rotorphile.
Ground the D3 pin, if it really is throwing a code 23. It shouldn't, since P28's don't read a knock sensor.
Old Sep 16, 2005 | 02:29 PM
crzy000's Avatar
crzy000
thank you kai, it works by grounding the d3 pin. I myself thought that the p28 don't read a knock sensor but some how it does.
Old Sep 16, 2005 | 09:49 PM
Kai's Avatar
Kai
Rotorphile.
No problem, I'm just confused that a D-series computer, in the 5th gen, needed a knock sensor...
BTW, grounding the D3 pin is making the computer think there is zero knock. Anything above 0 volts represents predetonation, so you should consider adding a factory knock sensor.
Old Sep 17, 2005 | 01:24 AM
crzy000's Avatar
crzy000
It's just temporary until he get the block that he bought on ebay...thank's
