help zc
Old Sep 5, 2005 | 06:48 PM
higguns's Avatar
higguns
Default help zc
ok so today i installed my zc and hooked everthing up. i go to start it and it starts on and off shaking and then stalls. we figure the distributor to be the problem, so we take it off and clean the points and the contacts and swap the coil from my d-series. put it back in and wire it up and go to start it and it starts but struggles. so i narrow it down to the fuel filter which we decided to use the one that came with the engine (jdm cuz it had jap writing on it). we take it off and the gas inside it is all discoloured so we put the one from my d-series on and starts up but still shakes so we rev it abit... at the most we went to 6000 rpm and it clears up, but then rite after it clears up it starts making a knocking type sound from the engine. the engine runs fine now and idles perfect, everything is fine except for the knocking noise. heres things i did to the engine/trans before i put it in: installed my crx si flywheel with a new clutch, replaced throw out bearing, swapped my crx oil pan cuz the zc one was dented, replaced oil pan gasket, installed new spark plugs, ported out my exhaust manifold to match the zc. my friend is an anprentess mechanic and said he cant figure it out cuz the engine idles pefect, but it makes a knocking sound and there are no codes. he said it sounds like theres something loose inside or something. i'm getting really fustrated and need your help, is this engine fucked or can anyone tell me whats wrong. i've been without a car now for a month adn i'm getting really fustrated.
Old Sep 5, 2005 | 09:19 PM
shady visions's Avatar
shady visions
is it a light knocking (ticking), or loud knocking (like, beating on a door) sound?
Old Sep 5, 2005 | 09:35 PM
90sicivic's Avatar
90sicivic
ACCORD & CIVIC TUNER
same thing i was gonna ask... if it is a loud knocking then could possiblity be one of your pistions.... did you check the crankshaft to make sure that all bolts were secure when you put the new oil pan on???
well let us know how this turns out..
Old Sep 6, 2005 | 04:14 PM
higguns's Avatar
higguns
k checked it out a bit more thoroughly and found the sound comming from the transmission. took off the flywheel cover and i can see the flywheel wobbeling and hitting the transmission casing i guess thats whats causing the sound. what could have happened i mounted the flywheel and tightened it as tight as i could with a ratchet adn used thread locker. maybe its the bearing???? oh and the flywheel wasnt resurfaced cuz it only had light burn marks on it.
Old Sep 6, 2005 | 04:19 PM
HatchbackHell's Avatar
HatchbackHell
To me it sounds like a rod bearing could have spun. That happened to my buddies Civic from him giving it too much hell. If this is the case your better off to find a new block depending on how extensive the damage is. If its the rod bearing, you need a new rod, piston, and an oversized bearing. Plus the crank shaft turned so its all even again.
