91 Crx Hf B16a1 Swap Help
Ok I recently bought a 91 CRX HF and dropped a b16a1 in it. I then put a light weight fly wheel, clutch and header in it. But now I am not shore where to go. I have 2g’s left in my build a REX account and need it to be pretty quick where do I go? I have already got the suspension and wheels on it.
What kind of performance can I expect from that engine in stock form in my REX?
When I pot a more aggressive cam and valve train in the engine what kind of gains should I get? What would I have to do to my car to go with a 75 shot with worrying about blowing it?
How about some ctr cams with upgraded springs and retainers. 2.5 or 2.25 catback. Have someone burn you an ecu chip. Aebs intake manifold with a ported typre rrrrrrrrrr throttle body, if you don't get a chip burned maybe get a vafc and raise your vtec a little bit to go with the ctr cams. Get some good tires on it, maybe lower it a few inches.
Skunk2 cams stage2
Skunk2 Cam gears
Skunk2 Valve springs
Retainers
AEM Throttle bodies
Intake manifolds skunk2
AEM Fuel rail
Fuel pump
Fuel pressure regulators
AEM Injectors
AEM Ignition systems
with this should i be good it's what i am ordering
Skunk2 Cam gears
Retainers
AEM Throttle bodies
AEM Fuel rail
Fuel pump
AEM Injectors
