?? About Timing Belt
Old Jul 29, 2005 | 11:12 AM
gingas's Avatar
gingas
Default ?? About Timing Belt
What all parts are changed when having your timing belt done & also are there any performance parts you would recommend getting while having that job done? Thanks for any advise....
Old Jul 29, 2005 | 11:26 AM
Tankard's Avatar
Tankard
Timing belt, water pump, alternator belt, a/c(if you have one)belt, and power steering(if you have one) belt, are the only parts you should need to buy, and the blue sealant stuff to rub around the water pump edges when reinstalling the new one. Can't help you out with the performance stuff.
Old Jul 29, 2005 | 02:00 PM
ChrisS's Avatar
ChrisS
Also, think about replacing the cam shaft seal(s) and the crank shaft seal.
Old Jul 30, 2005 | 03:02 PM
VPUPPY's Avatar
VPUPPY
do the items above along with the tensioner pulley. the tensioner spring is not necessary but for 4 dollars you might as well.
