Approximate total cost of engine swap?
Old Jul 26, 2005 | 11:46 AM
Tankard's Avatar
Tankard
Default Approximate total cost of engine swap?
Can anybody off the top of their head name all of the possible motors that will go into the 88-91 CRX within reason. Also, the horsepower of each and the approximate cost of the total swap, not including labor. I just read where a b18c would fit. Just curious how fast this little car would be with that motor? 12 second 1/4's maybe?
Old Jul 26, 2005 | 12:26 PM
mistacee's Avatar
mistacee
Zc powered ED9
This type of info can be found very easily. Don't make others do your homework.
Old Jul 26, 2005 | 12:28 PM
Tankard's Avatar
Tankard
I said off the top of your head. This would require no homework.
Old Jul 26, 2005 | 12:37 PM
mistacee's Avatar
mistacee
Zc powered ED9
It is not that hard to search....
any b series will fit
Zc and d series will drop in and bolt right in
h series requires work
Check here for prices...
http://hmotorsonline.com/shop/sc2000...USDM%20Engines
Figure $500-$1000 labor if your gonna have someone put it in for you.
Old Jul 26, 2005 | 02:51 PM
xpman's Avatar
xpman
Check out this link: http://www.hondaswap.com/forums/inde...howtopic=29825
I think the b16a is the best bang for your buck and it bolts right in.
Check this too if you're interested in the b16a: http://tech.hybridgarage.com/tech/b16/index.html
Old Jul 26, 2005 | 05:37 PM
VTEC-Power's Avatar
VTEC-Power
I paid installed for my B16a $2,750
Old Jul 27, 2005 | 08:35 AM
Tankard's Avatar
Tankard
If you had it to do over again, would you still do it? Was the extra power worth 3 grand? Is it all that much faster? Also, did you ever figure out your ticking problem?
Old Jul 27, 2005 | 06:25 PM
ED9man's Avatar
ED9man
driver
I did mine myself and got an LSD. It came out to a little over 3k but I had some other issues you might not have. The transmission cannot be rebuilt and they tend to have bad third gears, mine was already popping out when I got it and it quickly deteriorated. It's worth it, the stock motor sucks.
Old Jul 27, 2005 | 09:46 PM
VTEC-Power's Avatar
VTEC-Power
there is a huge difference in power from a d to a b series
Old Jul 28, 2005 | 05:39 AM
Tankard's Avatar
Tankard
What exactly does LSD do? I know it's something to do with the tranny and cost 300 more bucks.
