B16 ques
Old Jun 5, 2005 | 03:26 PM
CrxSiVtec83's Avatar
CrxSiVtec83
Default B16 ques
Ok........ I recently have decided to drop a b16 into my 88 crx si. I came across a b16a2 from a civic si that i had planned to use. My car i assume OBD0 and the b16 is OBD1 so do i have to convert this and if so what will i need to complete the conversion?
Sorry if this is a stupid question
Old Jun 5, 2005 | 04:05 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
The motor is odb2 and are you going to use the hydro tranny or a cable one?
Old Jun 5, 2005 | 04:32 PM
CrxSiVtec83
cable
Old Jun 5, 2005 | 04:48 PM
Kai's Avatar
Kai
Rotorphile.
Over a thousand dollars. Mounts, shifter linkage, axles and intermediate shaft, and various (expensive) electronic bits depending how you want to run the engine.
Old Jun 5, 2005 | 05:21 PM
CrxSiVtec83
So it would be like a b16a1 swap. I guess what i want to know is how simular or diffrent a b16a2 swap is from a b16a1 swap using a cable tranny in a crx.
Old Jun 5, 2005 | 05:27 PM
Kai's Avatar
Kai
Rotorphile.
The B16A1 doesn't exist. Don't confuse B16A generations with "A1, A2" etc.
The A2 in it's Civic and del Sol forms use hydro transaxles, as well as OBD-II management systems. Both have to be delt with prior to swapping into an OBD-0, cable trans CRX.
Old Jun 5, 2005 | 06:01 PM
CrxSiVtec83
Thanks for clearing that up for me . Would i be able to clear up the hydro transaxles proble by using a hydro tranny? Can i use a hydro tranny in a crx? And what would i need to convert the OBD0 (CRX) to OBD-II (ENGINE)
Old Jun 5, 2005 | 06:07 PM
Kai's Avatar
Kai
Rotorphile.
Buy a cable trans from a first gen B16A, that's the easiest way to do it.
If it was up to me, I'd modify the stock harness to run the new engine. Have a service manual and electrical troubleshooting manual ready.
Old Jun 5, 2005 | 06:13 PM
CrxSiVtec83
thanks kai , you have answered alot of my other posts and helped alot on this one.
one more question
Can you buy a harness that is aready motified and save some time?
Old Jun 5, 2005 | 06:19 PM
Kai's Avatar
Kai
Rotorphile.
HASport sells an add-on harness for first gen B16A's, but I don't know if they'll hybrid an entire harness for you. That would be about as much work as the 3G hybrid harnesses they sell for $350ish.
