power loss
Old May 15, 2005 | 01:42 PM
oc9crx's Avatar
oc9crx
Default power loss
My friend just bought an 88 crx si but it seems to be holding back on some power. He changed the oil, spark plugs, cap and rotor, and fuel filter. The car runs fine but it seems to be weak in the lower rpm, and a little just before the redline. I know this because we have two crx's that are exactly the same and both completely stock except for an intake. Someone told me it can be that the cat is clogged. Could that be our problem or is it something else?
Old May 15, 2005 | 10:23 PM
StreetRacingCRX's Avatar
StreetRacingCRX
None
I am just throwing this out there so dont get mad but run the highest octane fuel you can get from the gas station, and put some fuel system cleaner, You will be surprised what $10 can do. Also it allows for cleaner air which is better for the CAT. for $10 you cant go wrong
Old May 15, 2005 | 10:28 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would just run some injector cleaner through and see if that helps any. Did you change the spark plug wires?
Old May 16, 2005 | 06:54 AM
oc9crx's Avatar
oc9crx
Ill try some injector cleaner see if it helps, and no I havent changed the spark plug wires.
Old May 16, 2005 | 09:22 AM
Provocateur
On permanent hiatus
That would probably be a good idea.
Old May 16, 2005 | 09:38 AM
StreetRacingCRX
None
Just dont put fiel injector cleaner put fuel system cleaner, it is like $2 more but it does a lot more
